Quick selection method
Greetings all!
I have a question about quick select tool.
As you all know in BricsCAD v14 is an option of quick select.
After activation this option I want to select Mtext in DWG. It is not shown in object list (with asterisks) but it is shown in drop drop down menu.
After selecting mtext (from drop down) all mtexts are selected. Now I want to select mtext with specific content and that I can't see as an option when multiple mtexts are selected.
I think that it was different in Acad 2014 and I am wondering if there is an option for this also in BCAD.
Mtext which I want to change is located in layouts and I have several layouts.
I wolud like to select mtext with specific content on all layouts and change its position.
Anyone have a clue?
Thanks!
Bok!Po imenu vjerujem da znaš hrvatski. Možeš koristiti filter naredbu, ja sam je napravio (i objavio izvorni kod) ali nisam stavio opciju za Mtext (jer ga ne koristim). Moj izgled naredbe je vrlo sličan Autocadovom, Rakesh Rao je isto napravio filter naredbu (vjerojatno je uključio i Mtext).Rakesh Rao : https://forum.bricsys.com/discussion/15111Pozz!0
With Quick Select you can only select entities that are in the current space. This limitation is there because commands only work on entities that are in the current space. So what you intend to do is not possible with standard BricsCAD. It is however possible to create a (Lisp) program to accomplish what you want.0
