BricsCAD-Communicator
I have both BricsCAD V15 (x64) en_US & BricsCAD-Communicator-V15.1.01-1(x64) downloaded for trial, but I seem to be unable to import any Solidworks 2014 drawings. Not sure if I am going about it in the wrong way or whether it is a system problem. Do I open Bricscad as per normal and Import a 'solidworks' file, or do I have to run Communicator? The video is not very helpful, as it assumes 'all is well'
. Hope you can help.
As the message indicates, a license for Communicator was not found. In the BricsCAD pull down menu, please go to Help/ BricsCAD Communicator License and activate your trial.0
Brilliant!! Thanks. Did not realise I had to go to the help section0
