Can't activate my student license
Hello.
I've installed BricsCad V14 on Debian Jessie 32 bit.
I have a valid student license code (you accepted the request a month ago).
But when I typed it, BricsCad tells "Cannot get rehostable hostid. (Código de error -149)".
I eluded this problem a month by using an evaluation code.
Now the evaluation time passed and I retried to activate via my student code. But it fails again with the same error code.
Any ideas?
Any ideas?
The license file location has changed during V14.Make sure you use V14.2.19.Delete the directories /var/tmp/bricsys and /var/tmp/Bricsys, and reboot BricsCAD. You will have to re-enter your license key once more.0
I'm with 14.1.17 because it's the latest version avaliable in Spanish.
But it worked.
Thank you very much.
PS : How can I mark this as solved?0 -
>PS : How can I mark this as solved?You can't. This is a forum post, which does not have an associated status.Next time enter a support request. Here's how you could have done it for this issue:- go to the Support section of our website- click on the appropriate categories: BricsCAD>Licensing>Error codes- look at the listed articles- the error code you mentioned is not listed, so the logical next step is to enter a new support request:click "New Support Request" in the section "Didn't find what you were looking for?"Support requests are meant for bugs or technical questions towards Bricsys.The forum is meant for remarks/questions towards the BricsCAD user community, for instance to ask fellow users how they use BricsCAD for a specific task, or to share some lisp snippet...0
