LAYERP in Bricscad V15
I'm trying the LAYERP command in Bricscad V15.
I often use this command in Autocad after isolating a layer.
But on Bricscad, LAYERP only unfreeze layers one by one.
This is very annoying after isolating one layer among hundreds.
Is there a parameter to unfroze together all this layers ?
I know the layer state commands but this is really too long.
Thanks
  • Dear Philippe
    For the procedure you describe you do not need the LAYERP command. Please use LAYISO (Isolate layers) and LAYUNISO (Unisolate layers) instead.
  • Hello
    Thanks for your reply. This solves most of my troubles.
    But there's still the case when I freeze a lot of layers at one time using the drawing explorer ( eg all layers starting with blabla* ).
    Maybe I should send a support request ?
  • With groups of layers with my typical names, I still find it easiest to run script files to freeze and thaw them.
    Picked from my menu, they contain simple strings such as -LA F BW* T DW*
