NETLOAD in Classic version?
The versions comparison chart tells BricsCAD Classic version does not includes "Programming - .NET"
What does this exactly mean?
The NETLOAD command is not available, or it fails?
In the demo version it is not possible to switch between versions for testing it.
  • You can switch between license versions by changing the RunAsLevel variable. You can do this with the _SETTINGS command. You will have to restart BC.
    In the classic version the _NETLOAD command is available but it is a 'dummy' command.
    [code]: NETLOAD
    .NET is not included in your license.[/code]
