Hatch Patterns
I have Bricscad Version 14.2.17 (x64). I have copied hatch patterns into the default.pat and iso.pat files and they are still not showing up when I try to use them. What am I missing? Thx
This sounds like you may have multiple hatch pattern files on your computer and that the files you are modifying are farther down in the search path than another file of the same name.0
A quick way to find the file being used is to enter this on the command line:
[code](findfile "default.pat")[/code]0
