Moving a sheet set?
I have moved some of my projects from 2014 into a new 2015 directory, and now need to deal with some sheet sets. (2014 was the first time I started using sheet sets - I didn't have to deal with this before)
As many of you probably already know, the full path is apparently saved for each page. Now, in my case, the sheet set dwg files are all in one directory, which is the same directory where the sheet set .dsd file is located. I had hoped it would be able to find all the drawings, since the were all together, but no such luck.
Is my Sheet Set .dsd file now useless?
-Joe
Hi Joe,A dsd file is ascii so just open it in a text editor and do a find replace on the part of the path name that is incorrect.Daniel0
That was a great solution. In the past, I had tried to edit it to sort the sheet names, but found it to be impractical, since it was all HTML. But, since my path name is all the same, a simple search and replace was the solution.Thank you very much for the idea,-Joe0
