Display not regenerating
Sometimes when I highlight text within mtext (to edit the text) it does not display as highlighted unless i zoom in or out.
Similar when typing the text, when typing, the new text doesn't appear until i zoom in or out.
Is it Bricscad or my Graphics card settings?
nvidia GeForce GTX 760 graphics card should be more than enough to run Bricscad, no?
Thanks in advance for any feedback.
Cheers, Fonda
Cheers, Fonda
My video is a geforce GT 635 and I don't see that problem, I assume yours should be better if anything.
I have had files with mtext which behaved strangely in the edit box, often it's when the text width had been reduced to 0 by some accident.0 -
I see something like this when using tables. The old text in a table cell is persistent after it is deleted and remains visible as new text is added. In the example here I'm removing the old text with the delete key but, as you can see, its "ghost" remains behind until after new text is added and the editing is closed.Running BC15.1.20 on Win7 Pro (64) with a Quadro 2000M vid card. I've seen this same behavior on earlier releases -- possibly since tables were first introduced -- but it seems that there were times when this didn't happen. Never followed-through enough to file a support request, just worked around it.0
