V15 small bug
After DXF out and dxf in and save as dwg , then this dwg is removed.
Now I select open , but the type stays locked as DXF, not DWG
Can someone verify this?
Note, no can not fill in support request since no subscription.
Stefaan,
DXFIN uses the same file dialogue as the OPEN command. Importing a DXF has changed the default filetype to .dxf. To change back simply select .dwg from the file type drop down. Attach screen grab to illustrate. Closing and re-starting BricsCAD will also cause OPEN to revert to using .dwg
Also you don't need to have a subscription to file a support request. Simply go to the support section of the website, and if you don't find an answer to your question in the knowledge base, raise a support request from there.
Regards,Jason Bourhill
