getfiled
What's the problem with GETFILED order in LISP that allways return INVALID FILE NAME. It seems not to work.If anybody has an answearThanks
  • It does not seem to work with flag=2. Try a different flag, depending on what you are using it for.
  • Thanks for your answear, but i would like to inform you that the function (among others like pop-downs) doesn't work OKIf you set: 1 - It alerts you about overwriting, but even if you accept, it gives you Invalid file name. 2 - It gives you Invalid file name directly. 4 - Works OK 8 - Works like setting 2Of course any one of them, let's you to write a new file name (It is as if you are not allowed to use this function to set the name of a new file, deciding where to put it.It's hard to pass the routing from AutoCAD to Intelli!
