V15, Open Drawing, customizing side bar, favorites
Hi everyone,
in V15 I tried to customize the side bar of the "open drawing" menue, using UseStandardOpenFileDialog=0 and PlacesBarFolfer1-4. But V15 opens always the standard file dialog and not the customized. In the older versions, this was no problem.
Funnily enough, it worked once and then never again.
Any idea?
best regards
Frank
  •  I'm having same problem, running Version 15.3.05 (x64) revision 39062 on Windows 8.1x64
    Dan
