bug coming in a drawing
In case of larger drawings with a lot of tasks are there crazy bugs. And those are always different. I have a weak PC or regenerating I too little? If I use the ' tired ' drawing copy to a new leaf is also the bug off. How is this phenomenon.
  • Try running the _AUDIT command when you experience those strange bugs. I do not think your problem can be related to something like the _REGEN command.
