copying a drawing
one question: can I copy a drawing to a new sheet, which I also all set layouts copy too. Also modelspace en all the layout on a new sheet
Use the _WBLOCK command and select the 'Entire drawing' option in the dialog.0
Just like any program, you do a save-as to save the drawing to a new drawing with a new name and/or path. The model space, tabs, and all settings for that original drawing will be in the new one.Also, if you just want to put something in a paper space tab, you can insert blocks, and copy/paste from model space into paperspace. Even 3D objects can be pasted there, though you can't change the view point, or do hidden line removal.-Joe0
