WSSAVE command issue.
When you call the "WSSAVE" command from Lisp in BricsCAD you have a different behaviour form AutoCAD.
Example:
(command "_WSSAVE" "MyWorkspace")
In AutoCAD the above code works fine, in BricsCAD you see a dialog that wait for the user to specify the new workspace name.
Hello Francesco,
this is the USER forum for BricsCAD, where users can communicate with other users.
To report problems with the application to Bricsys staff, so that they will be investigated and addressed, please use the support request pages instead.
Kind regards,
Hans0
