Differences between BricsCAD and AutoCAD ribbons.
 If you load ribbons from a CUIX file you may see the following differences (look at attached image):
  1. Pulldown panels are ignored by BricsCAD.
  2. Some large icons are not shown at all and some small icons are shown uncorrectly.
  3. The labels forced to two lines using the "\n" code (i.e. "TextRow1\nTextRow2") are shown on a single line.
To reproduce the problem you may try to load the attached .cuix file.
  • Hello Francesco,
    this is the USER forum for BricsCAD, where users can communicate with other users.
    To report problems with the application to Bricsys staff, so that they will be investigated and addressed, please use the support request pages instead.
    Kind regards,
    Hans
