MENUBAR system variable is not supported.
If you want to use just the ribbon interface you are not able to hide pulldown menus.
In AutoCAD for this purpose you have the MENUBAR system variable, in BricsCAD such variable is not supported.
I also want to use only Ribbon interface and disable pulldown menus. I've tried MENUBAR but this variable is not supported.Do you know another alternative to disable pulldown menus?Thanks0
