Missing lisp.dll file
Recently when I go to open the BricsCad program, I'm now getting an error message, reads :" lisp.dll is not loaded or corrupted; exiting now.....".
How can this be fixed or remedied.? The files are not in the Bricscad directory, they seemed to have vanished.
Any help would be appreciated. Thank you.
  •  Your best bet would probably be to try to repair the installation using the BricsCAD installer, failing that, I would completely uninstall and reinstall...
  • We don't deliver a lisp.dll. We do have a lispex.dll and three other files lispex.ext, lispex.lsx and lispex.dll.cfg . If an antivirus has removed the dll then it most likely will do so again if you reinstall. But we have not had any reports yet of these files being removed by an antivirus.
