HOW TO DISABLE OLE IN SETTINGS
 whenever I use copy and paste, my file default to OLE. How to disable OLE in settings. See attachments below
Michael Cokwana
  • Michael, to get an 'OLE' result similar to yours I have to take these steps:
    1. Open falakahleN.dwg
    2. Select the 'table' portion (= separate lines and texts).
    3. Use Ctrl+C (= COPYCLIP).
    4. Open a new drawing.
    5. Use Alt+Ctrl+V (= PASTESPEC) and in the dialog select the 'Picture (metafile)' or 'Bitmap' option.
    To get 'normal' BricsCAD entities you can do two things instead of step 5:
    A. Use Ctrl+V (= PASTECLIP).
    B. Use Alt+Ctrl+V (= PASTESPEC) and choose 'BricsCAD entities' in the dialog.
    I am not sure why you have abandoned your other topic related to this problem.
