BricsCAD and point clouds
Hello
I'm buying a 3D scanner.
I would like to know if BricsCAD V15 is able to attach point clouds ( PCG files ) like AutoCAD does, and to work on it.
Thanks
Philippe
Thanks
Philippe
Hello Phillipe,This is a software provider who developes point cloud applications: Kubit SoftwareThey already offer at BricsCAD catalog a "small" range application, named VirtuSoft: https://www.bricsys.com/common/applications/application.jsp?app=702&apploc=Hopefully they might be interested to extend their features in another application: PointSense, which has stronger features. Would be nice if they port it from AutoCAD to BricsCAD as well.You could make them a call for this. It would encourage them to step on.Best regards,Miguel0
Their PointSense Plant is exactly what a client is needing, I have sent them a message asking about a BricsCAD version...0
Hi Phillipe,There is also the software called pointcabJust Check it out.Best Regards.Mustafa0
Thank for your replies.
I will analyze this softs. I'll tell you the one that seems most appropriate.
Best regards
Philippe0
