HELP WITH COMMAND EXTRIM FOR BRICSCAD V11.0
 Hi.
I am working with Bricscad V11.4.1.
I need the extrim command but the command do not exist in this release.
Please, help me whith an autolisp command similar to the extrim command.
Who can help me with an autolisp solution?
Thank's.
  • This is a command from ExpressTools, installed by default with AutoCAD.
    There is also an "ExpressTools for BricsCAD" freeware utility - please check the application catalog.
  •  Ok. Thank you. so much.
