Data extract and data link
 I'm trying to manage my drawing sets using an excel sheet and exported CSV file and wondering if I can use the data link commands to run it rather than having to build or use a VBA interface or script runner.
Anyone with any tips on how I can do this?
I have a standard title sheet with an attributed block for the title sheet contents
"TITLE_LINE_1"
"SCALE"
Each column in the excel sheet has the same attribute name as above along with an initial column for the file name
Cheers,
Liam
  • What do you mean by:
    'manage my drawing sets'
    and
    'to run it'
  • You are asking if there are any built-in commands for linking data to a spreadsheet in BricsCAD? I don't believe there is. For your case, an alternative may be to consider using _SHEETSET this however doesn't use a spreadsheet to maintain. Have you looked in the application catalogue? This seems similar to what you're asking for GlobalCAD Schedule
    CAD Concepts
