LISP SOUND
HI,
I am developing a LISP program and I need the program to make a sound (for example, when an error occurs).
Is there any way to do that?
Thanks
This is a stripped down version of the original SayItNow.lsp I found years ago.
; Program Name: SayIt.lsp
; Created By: Terry Miller
; Date Created: 1-20-07
; Function: Says Phrase$ through computer speakers
; Note: This will only work on systems after Windows 2000.
(defun SayIt (Phrase$ / Sapi)
(vl-load-com)
(setq Sapi (vlax-create-object "Sapi.SpVoice"))
(vlax-invoke Sapi "Speak" Phrase$ 0)
(vlax-release-object Sapi))
(defun c:SayItNow (/ )
(setq sMsg "Hello World")
(SayIt sMsg))0 -
If a 'nasty' beep is OK you can use:
(vlr-beep-reaction)
Or, even worse:
(acet-sys-beep int)
Int can be: -1, 0, 16, 32, 48 or 64.
I personally would never use a 'beep-on-error' feature.
If you do introduce it, make sure the user can disable it.0 -
Thanks Donald.And thanks Roy again0
