Menu
Can anybody send me an ICM menu file.What's the difference between MNU and ICMThanks
You can easily create this file yourself -go to Tools>Customize>Menus>Export.There is no difference (in principle) between the two file types. A .mnu file is easier to edit manually, since you don't have to care about the numbering sequence.
an icm has different formatting and has additional control over menus. Each item can have a field containing an extensive set of visibility flags to control when it should be visible and active.With menus each pop has a default value. sander bricsnet
