Block insert
Hi having used another since long dead cadsystem I still miss a little feature. I would like to have two insertpoints on a block ( maybe even 3 för 3D). First piont fixpoint second Point direction and/or scale. Its very useful to scale graphically when inserting. Anyone knows how to achieve this??
When you get the insert dialog box, there are check boxes above the insertion point, the scale, and rotation. You can either pre-set them in the dialog box, or you can indicate them on screen.-Joe
Yes and no I would like it to work like the align command. Very useful .
Howdy, Stranger!
