How to get Tips to work on a Mac
If I enable TIPS via the status bar, and use a command such as extrude, a little bar pops up that shows a ?, a CTRL key, and some options. I'm assuming that if you hit the ctrl key you can switch between the options. This doesn't appear to work on a mac. I've tried the ctrl key, command key, fn key, and several combinations. Is this just not available on the mac, or am I doing something wrong?
Thanks,
Dan
Hello Dan, the tips widget should be fixed on mac in V15.2.The tips widget exists in V15.1, but it blocks key processing. This is a known issue, and has already been fixed internally.In V15.1, the tips widget has been disabled by default. V15.2.02 will be published as a beta version soon.RegardsTijs0
Thank you! That 's excellent news.0
