Multi-Delete Layouts
Hello all BCad users,
Sorry if this tread is open elsewere, but, can you say if it's possible to multi-delete layout on Bricscad V15? Doing this in a proj with 50+ layout it's hard.
Please help.
Many thank's.
Luis.
  • Hi,
    You can do it in Drawing Explorer-Page Setups.
  •  Thank you Marin, it works fine.
    Luis
  •  Cool trick, wish I had know about that a few months ago...
  •  [code];;; Delete all layouts
    (defun c:DeleteLayouts ( / name cname)
      (vl-load-com)
      (setvar "cmdecho" 0)
      (setq cname (SDG_Get_CLayout))
      ;; if in modelspace, create new blank layout to allow deletion of all existing paperspace
      (if (= "Model" cname) (command "layout" "new" (setq name (strcat "temp_" (rtos (getvar "cdate") 2 6)))))
      (vlax-for x (vla-get-layouts
    (vla-get-activedocument (vlax-get-acad-object))
        (if (and (/= "Model" (vla-get-name x))
                 (/= name    (vla-get-name x))
                 (/= cname   (vla-get-name x))
             ) ;_and
          (vla-delete x)
      (if (= "Model" cname) (command "layout" "rename" name "Layout1"))
      (setvar "cmdecho" 1)
      (princ)
    ;;; Get current layout as string
    (defun SDG_Get_CLayout ( / clayout)
      (if (SDG_is_paper)  ;if paperspace, return layout name
        (setq clayout (vla-get-activedocument (vlax-get-acad-object))
              clayout (vla-get-name (vla-get-layout (vla-get-paperspace clayout)))
        "Model"
    ;;; SDG_is_paper - returns nil for modelspace, T for paperspace
    ;;;  by Vladimir Nesterovsky
    ;;; use (cons 67 (if (SDG_is_paper) 1 0)) for ssget "X" of mspace vs. pspace
    ;;;  note that pspace will get all objects in layouts, not just current
    (defun SDG_is_paper () (> 2 (getvar "cvport") (getvar "tilemode")))
    [/code]
  •  Thank you for the code. It helps, but... only if i want to del all layouts, yes?
    It's a start.
    Luis
  •  It deletes all layouts but current, if you are in a paperspace layout. You could easily add an option to do a name check. Or check into dos_lib GUI functions to make dialog with list of layouts for selection.
