Publishsing sheetset to PDF
in Linux
Hello,
I am usually printing only to PDF through the bulit-in PDF export. I always create a sheet list (.dsd file) or a sheetset (.dst file) with all of the sheets in the project, that I often publish. In th publish dialogue I set 'PDF' as 'Publsih to:' option, choose otput location and set file name. This way everything works. But when I load this .dsd file again, the 'Publish to:', file location and file name are not loaded. Is this a bug or intended behaviour? Does anyone have a workaround, so that one doesn't always have to re-set all of those values every time new sheet list is loaded?
