Problem with Vector Displacement
When I copy an object, I type in "c", select the object with a crossing window and right click. Frequently the object is instantly moved by a vector displacement. The only way to avoid this problem is to copy and paste VERY slowly and deliberately. This is really a problem for me while drafting as I am used to copying and pasting objects very quickly. Does anyone know why this is happening? Is there a way to disable vector displacement?
I am not seeing the value of the vector displacement option for the way I draft. I draft architectural drawings for small home renovations. I don't see why having to type in precise vector points would be useful to me. It seems extremely time consuming when all I want to do is to quickly copy and paste an object from one area and pop it into another.
I thank anyone in advance who can help me.
Dear TamaraCan you have a look at the command prompts when using the Copy command? The default procedure is as follows:1. Start the command.Prompt: Select entities to copy:2. Select one or more entities.Prompt:Entities in set: 1Select entities to copy:3. Right click or press Enter to stop selecting entities.Prompt: Enter base point: mOde/Displacement:4. Specify the base point.Prompt: Enter second point: :5. Specify a point.The entity is copied over a distance between the two points.Vector displacement is started only if you respond with a right click or pressing Enter at the prompt in step 3. Do you experience otherwise?0
Hi Tamara,
If you're not worried about precision, then you can use Click n Drag to move and copy objects on your drawing
Regards, Jason Bourhill CAD Concepts0
