How to Make a Block Explodable
So I created a block using the block command and didn't notice that the Allow Exploding checkbox was unchecked.  Using the block editor in AutoCAD you were able to change this setting, however BricsCAD doesn't have the block editor, and the Allow Exploding drop down in the properties panel when one selects a block doesn't allow you to change the setting.  Is there a built in way to change this setting?  I did find a script, linked below, which changes all blocks to allow exploding, however, for some this might not be an option if you don't want all of your blocks to be explodable.
  •  Tools > Drawing Explorer > Blocks and check Explodable.
  •  Ahh, the answer was right infront of me the entire time, I had seen the check box but had never looked to see what it did, thanks for the eye opener!
