Bricscad v15 not displaying/printing shx fonts properly
 For some reason, suddenly any text on my screen that uses Romans.shx displays too "thin" and is barely visible on my screen. I'm not sure why this is happening. My view is set to 2d wireframe. It happens on the display and printing as well. Whenever I print, my text line thickness will be extremely thin even though I have it on a layer that should be printing it thicker. I'm not sure how to fix this. Please help!
  •  I discovered my problem. I was not selecting the .shx file in the drop down. Apparently there is some other type of font it was trying to use instead. I copied the fonts to another directory. Pointed Bricscad support location to that new folder and now I can select the .shx font. They also appear in the top of the list, not in alphabetical order.
