Annotative callout blocks
 I have a new set of dynamic annotative call out blocks (see attached) originally from Cadlispandtips
They are fine if I use them in paperspace with an annotation scale of 1:1
but once I put them into model space and set the scale (1:50 m for example) the text is shifted and away from the the line work.
Is this an issue with Bricscad or an issue with the blocks?
As a work around I can keep them at scale 1:1 and CHSPACE from paperspace to model space and they are scale correctly but then I can see them as they have an annotative scale of 1:1 while my viewport has an annotative scale of 1:50 m.
Cheers,
Liam
  • Hi Liam,
    Its a BricsCAD thing, it can't cope with the combination of annotative scaling with a dynamic block. The attributes scale, but move from their correct location. I would raise a support request to get it fixed.
    In the meantime they work fine as dynamic blocks in paper space at 1:1 i.e. without the annotative element. Good find, nice blocks :-)
    Regards, Jason Bourhill CAD Concepts
  •  Thanks Jason,
    I'll post it up as a request.
    Yeah he has some pretty good freebee stuff on his site, the lisp routines are awesome.
    Paperspace it is or I make a simple set without the dynamic function...
    Cheers
    L.
