Right mouse click on version 15.2.08
Hi All
Anyone else noticed this?   I loaded the new version yesterday before leaving the office.  This morning I try to draw and immediately notice that my right mouse click will only act as an enter key.  Normally my right mouse click always brings up a shortcut menu.
I checked the shortcut menu settings in the options menu and they are all checked as before.   Is there a new setting that I am not aware of that controls the right mouse button?
Thanks
Doug
  • Never mind I just discovered that if you pause on the right mouse button the shortcut menu appears.  If however you just click the right mouse button then the enter function occurs.  So it works sort of.    Setting to turn this feature off?
  • See SHORTCUTMENU in Settings ... a new bit value (16) was added, which controls immediate or delayed display of shortcut menu :-)
    Many greetings !
