COM interface with Python: Cant access the Name property of an AcadBlockReference object
I try to find out the which block is refferenced by a AcadBlockReference
import comtypes.client
acad = comtypes.client.GetActiveObject("BricscadApp.AcadApplication")
doc = acad.ActiveDocument
model = doc.ModelSpace
model(121).ObjectName
This gives the result: 'AcDbBlockReference' - 121 is indeed a block reference
Now I try to acces the name of the referenced block:
model(121).Name
I get the errormessage
Traceback (most recent call last):
File "C:\KBApps\Python34\lib\site-packages\comtypes-1.1.1-py3.4.egg\comtypes\__init__.py", line 275, in __getattr__
fixed_name = self.__map_case__[name.lower()]
KeyError: 'name'
During handling of the above exception, another exception occurred:
File "", line 1, in
model(121).Name;
File "C:\KBApps\Python34\lib\site-packages\comtypes-1.1.1-py3.4.egg\comtypes\__init__.py", line 277, in __getattr__
raise AttributeError(name)
AttributeError: Name
I cant find the reason for this. The COM documentation says that an AcadBlockReference object has the property Name.
Best regards
Heinz-Otto
(Win7 x64 SP1, Bricscad V14.2.11 (x64), Python 3.4.3 64 bit)
Is it only the Name property that causes an error, or do other properties cause the same error? For example, what happens if you access the EffectiveName or ObjectName properties?0
It is not only the Name property, the EffectiveName property shows the same errror. The Objectname property is available. The python ide show a list of available properties and methods while entering code. For the block reference the properties Name and Effectivename are missing in this list (see screenshot).
PythonPickList.jpg0
