Frequent crashes
Whenever I insert too much references on a drawing, it becomes too large or too overloaded or something like that. Then when I just move the pointer through the drawing (lines, hatches etc..), or enter commands (move, scale) the program crash and exit without saving. I was using demo version, could it be because of that? I am thinking of buying the software, but how can I be sure this doesn’t happen a lot.
Hello,
the only difference between an evaluation version and other versions is the license key type.
Please be informed that we provide support to BricsCAD users 'from day 1", that is, also during the evaluation period.
If you file a support request and attach a sample drawing with which you experience these frequent crashes, we will be glad to look into the issue.
For this specific case with reference files, please pack the drawing and the referenced drawings in a zip file and attach that to the support request, along with a short description of which actions our analysts should perform to trigger a crash.
Best regards,
Hans0
