Snap Symbols Do Not Show
Snap works but the symbols don't show. Kind of hard to snap to a midpoint.
This seemed to happen on its own.
Any ideas?
  • Display of snap marker symbols is controlled by flag 1 of the AUTOSNAP setting.
  • I set AUTOSNAP to 1 instead of its previous value of 0.
    Snap symbols are back!!
    Thanks again, Hans. Problem solved.
  • The AUTOSNAP setting is a collection of 'flags' that can be set, AUTOSNAP stores the sum of the active flag values.
    Please open the settings dialog and have a look, probably you will want to enable more flags than just the one for snap marker display.
    Usually the value of my AUTOSNAP system variable is 63
