Viewport bouny visible in tif image
We need to generate tiff images using Landonline "Print-to-tif" driver. When the tiff is created, the viewports boundaries appear as lines in the tiff image. Is there a way of printing without the viewport lines being displayed?
In the layers dialog box, you can choose any layer to not print. If the layers with the viewports is set to not print, then they should not show.-Joe
Grant,
Also check your setting for IMAGEFRAME
The help is a little out of date. Imageframe can be set to the following values:- 0 = Imageframe is OFF, and won't print.
- 1 = Imageframe is ON, and will print.
- 2 = Imageframe is ON, but won't print.
Regards,Jason Bourhill
Howdy, Stranger!
