V14 Text with 2D constraints
I have a parametric drawing, which has some text labels that I would like to keep in its proper position when the object changes shape.
I tried adding a coincident constraint to the insertion point of text, but that was not a valid constraint. Does anyone have any ideas about how to achieve this?
-Joe
You could try using a Dimension, suppressing the dimension and extension lines leaving just the text element. Attach an example.
Very clever!-Joe0
