Communicator trial not working?
Did you download and install the communicator module? It's a separate download to BricsCAD
That's probably the culprit right there. Thanks Jason!0
Hello Jason,Please provide additional instructions, as Communicator V16 will not open a SLDASM file, which V15 did open. I had been using the trial version of Communicator V15. I removed both Bricscad and Communicator V15 before loading V16 of each. Bricscad V16 Pro is running well, with its new licence. Communicator is still on the 31-day trial.Dan S.0
Hello,
I also have problem using trial version of communicator. I have new V19 Bricscad Pro installed on my PC. I got STP file from my customer and tried to open it, then noticed I need communicator module also. Then I downloaded trial version, but it's not working at all. Only appears icon that Bricscad communicator license is not activated. So I downloaded other STP viewer.
I manage Bricscad licenses in our company, and I am little bit annoyed about new pricing policy in Bricscad nowadays, I think we don't get value for money for higher license fees. Perhaps we search another program.0 -
As a new BricsCAD user of about three weeks, I cannot get the trial version of Communicator as the corresponding BricsCAD Platinum v19.1 compatible release to work. When invoked, a message states that I have no license to use Communicator.
Please provide a solution or confirm this issue as a problem with the application.
Type UseCommunicator in the command line, then set its value = 2. Close and restart BricsCAD.
