plot to file
I have ICad 2001A PE. I want to print a "raster heavy" file (700MB) on an Epson Stylus Pro 9550 at the local 60 Minute Photo shop. I need to supply the file to the shop on a CD-ROM in a .plt or .prt format. I can't find a "plot to file" option anywhere in the print process. I already downloaded the driver from the Epson site. Can anyone help me? Thanks
hi,you have to install your printer in a second way. the first sholud be connect to the port lpt1 (or lpt2), but the second should be connect to file.choose "new printer" and then take all settings... the most important settings is the port "to file" - at the end of the list.now you can open the print-dialog of intellicad and there should by two different printers (o.k. the same printer, but with two different ports...). selcect "epson... to file" and you write a plot-file
