*.stp files
Other than the Communicator is there some way to get step files into BricsCAD? That is the only file conversion I really need. STEP>DWG>STEP
I tried the Sycode plugin, but it is not compatible with the latest update (actually since v12...)
Thanks for any help/insight.
Nick
There is CAD Exchanger, which is available as a free download for the GUI evaluation version. The evaluation versions are time limited.
You would go [STP -> ACIS] in CAD Exchanger then [ACIS IN -> edit -> ACIS OUT] in BricsCAD and finally [ACIS -> STP] in CAD Exchanger again.0
