Adding multiple hyperlinks to a single object
I'd like to add multiple hyperlinks to a single point object preferable using vlisp. Is this possible ?
thank you !
  • I don't think thats possible.
    i knew only one link to one Object
  • All drawing objects have a hyperlinks property. Because this is a collection it can contain multiple items. But only the first hyperlink is displayed to the user.
    [code]; (AddHyperlink (vlax-ename->vla-object (car (entsel))) "http://www.b-k-g.nl/freeware.html" "Freeware for BricsCAD" "top")
    ; (AddHyperlink (vlax-ename->vla-object (car (entsel))) "http://www.geopus.com/" "" "")
    (defun AddHyperlink (obj url urlDescription urlNamedLocation / lnks)
      (setq lnks (vla-get-hyperlinks obj))
      ;; Remove existing links with the same url:
      (mapcar
        '(lambda (lnk)
          (if (= (strcase url) (strcase (vla-get-url lnk)))
            (progn
              (if vle-fastcom (vle-fastcom nil)) ; Required for V14.
              (vla-delete lnk)
              (if vle-fastcom (vle-fastcom T))
        (vle-collection->list lnks)
      (vla-add lnks url urlDescription urlNamedLocation)
    ; (AddHyperlinkList (vlax-ename->vla-object (car (entsel))) '(("http://www.b-k-g.nl/") ("http://www.geopus.com/")))
    (defun AddHyperlinkList (obj lst)
      (foreach itm lst
        (AddHyperlink
          obj
          (car itm)
          (cond ((cadr itm)) (""))  ; UrlDescription.
          (cond ((caddr itm)) ("")) ; UrlNamedLocation.
    )[/code]
  • thx Roy !
    To bad only 1 link is shown, is this the same in ACAD. I have to link pictures to points.
    So the only option is to write my own hyperlink viewing tool i guess.
  • Getting back on this i have the following issue: i cannot seem to use relative path settings.
    hyperlinkbase setvar = ""  If this is empty the drawing path is used as base.
    In the dialog it shows the drawing path (hyperlinkbase) correctly, however when i next enter a subpath + filename in the field for filename, the link doesn't seem to work.
    I'm assume you can use a subpath or am I wrong ?
    ty
