Snapping in Windows 8.1
Just installed version 15.3.05 on my 8.1 pro and all seems well except snapping. I don't get the square symbol showing the snap point (a corner or midpoint) and some strange distortions show up next to the cursor. If I am drawing a line from an endpoint for example, the line start somewhere else on the screen while the mouse is down but it shows up correctly after I release.
Anyone encounter the same issues? Any help?
Thanks, Al
Check that you have up to date video drivers. In BricsCAD, you can run the command REDSDKINFO. This will generate a report from the rendering engine as to the drivers it is using and whether it believes there are updates.0
