DXFIN Script
in Other
I have a script that does a DXFIN and then does other stuff that doesn't matter right now. The thing is that the dashdotted lines and the dashed lines are "shrinked" and look almost like continuous lines.
I have changed the INSUNITS variable but it's the same.
By the other hand, when I do the DXFIN in the command line, it works perfect.
I have tried everything, including making the script just to do the DXFIN and it happens the same.
I tried it in Autocad and it works perfect, so must be something in Bricscad.
Hope you can help me.
If called from a script the _DXFIN command imports the DXF into the current drawing. Called from the command line _DXFIN opens the .dxf file. Using the _OPEN command in your script instead of _DXFIN should solve your problem.0
Thanks, it worked just right.0
