Lost mouse when dimensioning
in Linux
Hi all.
This is my first post here in the forum.
Hopefully I can explain well my mouse issue.
Though I am using english, this is not my first language and not very fluentin expressing my thoughts.
As the title says, whenever I start my dimensioning, as soon as I click the dimension button
the mouse cursor seems to hide, so it is so difficult to point to the entity that I want to dimension.
The cursor only hide in the origin of the first extension line and for the second extension line it is shows up.
It makes working in the dimension too hard with this because I have to aim my mouse on a trial and error basis
until I see the snap appear when it hit the target.
I am using BricsCad Classic ver.15.2.11-x86_64.
Thanks in advance for oyur help.
Hello,welcome to the BricsCAD forum!Your description is clear.I tested and I confirm this issue.I have created internal development issue #5539 to work on this bug.Mind that this kind of issue, a plain bug in BricsCAD, is most relevant to be entered in a support request.Everybody is free to enter support requests, even when using BricsCAD with a trial key.Can you still enter a support request about this issue, and mention internal 'Redmine' issue #5539 in your support request?(Redmine is the internal bug tracking system that we use)That way we will be able to inform you about progress regarding this issue.Kind RegardsTijs Vermeulen0
Thanks for your reply.
I think this issue with the mouse is 64bit specific.
After I posted this thread, I went to the download page and tried the 32 bit version.
The 32 bit version has no problem with the mouse in dimensioning.
With the support request I will try to submit mine.
Thanks.0
