Collada dae export seems not working
in Linux
I am using BricsCad Classic ve15.2.11.
I can export and save into collada dae format but every file is save 664 KB. It doesn't matter if it small or large file.
If I try to import the exported collada dae in blender cycles, it is empty.
Thanks in advance for your kind help.
Hello,Can you please enter a support request about this issue?You might find this forumpost interesting:Kind RegardsTijs Vermeulen0
Thanks for your reply, I will try to submit a support request.
With regards to your link, I saw it yesterday and noticed it is working on version14.
I would like to add some observation with this collada dae issue.
If I export a 2d drawing,(I can only use 2d because my licence is for classic) with text and solid,
solid and texts appear in the exported drawing to collada dae, the lines circles, rectangs are not generated.
I am thinking that maybe BricsCad collada dae export support only solids, mesh or 3dfaces. Maybe someone
can confirm about this.
I would like BricsCad to be the same as sketchup does. it export all lines to collada dae with no problem.
This collada dae export is the most important part of my day to day work, because this is the only way to
transport the cad drawing easily to blender with out a problem.
I would like to mention also that both 32bit and 64bit linux version has the same problem.
Thanks,
Tanto0
