menu spariti
Buon giorno
all'avvio di bricscad 15 per windows ottengo il messaggio che vedete in allegato. Parte lo stesso, ma senza menu.
  • The default.cui file contains lots of application configuration settings, amongst others also the definitions of menus and toolbars.
    The message indicates that the file cannot be read.
    You could replace this file by the original default.cui file which can be found in one of the BricsCAD installation folders, on your machine it will probably be this one:
    C:\Program Files\Bricsys\BricsCAD V15 it_IT\UserDataCache\Support\it_IT
    Please note: by replacing default.cui with the original one, any modifications you made to the user interface (toolbars, menus) will be reset.
    Kind regards,
    Hans
