polar tracking and line extension
i want to learn polar tracking setting with my autocad as you see on video and then how can i extension line without using +
Check help for setting polar tracking and add angle tracking
very good idea ?0 -
Dear AhmetWhat you are looking for is Polar Tracking and Entity Snap Tracking, which is switched on/off by clicking the POLAR and STRACK fields in the Status Bar. According to what I see in your movie, the Polar Angle setting needs to be set to 45 and the 'Use polar tracking settings in entity snap tracking' option of Polar Mode must be checked. You can access the settings needed by right clicking on either the POLAR or the STRACK field in the Status Bar and choosing 'Settings' in the context menu.In the second part of your movie it seems that the 'Associative' property of dimensions is switched off. As a result the dimension does not update when the length of the line is modified. This is controlled by the DIMASSOC system variable. Set DIMASSOC = 2 for creating associative dimensions.0
