Printing Problems
With the latest version of Intellicad I'm back to having an infuriating problem that was fixed in an earlier version: When the line colours are mapped to black in the Print settings dialogue this colour (black in my case) is overridden by the colour of the editing screen?! For instance I use a mid grey screen, so even though the "output colour" is named "black" the colour that is in the little rectangle and which is printed is mid-grey. If I use a white screen the output colour is still labelled as black but shows as white. Therefore I have to use a black screen to print!! Can you fix this ASAP?Nick
If you want to print black. Map all colours to white not black.White prints as black , black doesn´t.
Thanks.(So much for logic!!)Nick
