XDWGFADECTL - didn't work
Hello everyone
I have problem with command XDWGFADECTL. I have BC 15.3.05 (x64) rev. 39062. No matter what value I'll put the program always remembers 70 and fade didin't work. Please help
Hi Tomasz,
Do you mean that if you set XDWGFADECTL to 30, then close and restart BricsCAD and check the value again, it has changed back to 70?
Hi Owen,Exactly!I set value to 30, then I check again - 70
. It looks like the value 70 was fixed and can not be changed.
I think this is problem with my Bricscad. I installed the same version of the program on another computer and it's works!Reinstalling the program does not help.0 -
Is there any code in any of the start-up files that could be setting this value?0
What start-up files can that be? I must check. What I should looking for?0
What start-up files can that be? I must check. What should I looking for?0
Tomasz, as Martin has suggested, it's likely that you have a startup file (like on_start.lsp or on_doc_load.lsp) setting the value to 70.0
Ok. Tomorrow I check these files.0
Ok. Tomorrow I check these files0
I found the source of the problemI use a program FDBES Ventpack (for HVAC) and he is a problem
. Thank you all for help.
I'm glad you found the reason. Thanks for following up!0
