Dimension Setup vs List Command
I set up my dimension style as Architectural; but when I use list command the length shows as in inches (Ex.:120.36); how do I get this dim to show as Architectural also? Thanks in advance for your help.
Raju
In the Units command, the variable LUNITS will allow you to choose what units the list and properties show.-Joe0
Thank you Joe. That worked. Awesome!0
In the _SETTINGS dialog look for LUNITS and change to architectural.0
I wasn't quick enough...0
No sir. More the merrier. New to BricsCAD and very happy with the quick answers. You guys are good.thanks0
